From what I have seen, Excitel does not let you use custom DNS servers like Google Public DNS or OpenDNS. Unless you are using VPN, you are using Excitel's own DNS servers.
This is generally fine but I am having issues with bunch of domains that are inaccessible randomly.
Right now I cannot access linksredirect.com for example even though it is supposed to be up. clnk.in is also not working though it seems to be down as per downforeveryoneorjustme.com. yesterday, i had to use vpn to order a product through ebay because ebay india was struggling to load on excitel.
just curious if you guys have also faced similar issues.
Update: Both clnk.in and linksredirect.com are working if I use VPN so the problem is definitely with Excitel's DNS Servers.
Excitel users, please check these two domains and confirm if they load at your end!
