Does the Nokia G-2425G-A have the same bitrate on each LAN port?
i got my Airtel Xstream broadband relocated and have the G-2425G-A ONT installed. I am getting max speeds of 100 mbps on LAN ( I am on a 200 mbps plan) . Any ideas on what could be causing this. I am using an Asus Gigabit router as my main router ( connected to Lan 2 ), LAN4 is used for intercom (in bridge mode)
Had the same issue - get your cables changed. The router supports Gigabit connection for all 4 of its LAN ports.
The router is GT AX11000. I dont think the router is the issue here. Called the airtel technician & as per him its probably a case of bad wiring which is causing the connection to drop.
I am facing the same issue.. I have a 200 mbps Airtel Xtreme connection on 1st floor but getting a max of 100 mbps with connected routers on ground and 2nd floor.. I see a maximum bitrate of 100 mbps on the router setup page.. I don't think it's a wiring issue.. if you still think it's then connect a lan from Airtel/Nokia router to your laptop and check
