Hey Guys, I'm new to this forum, so forgive me in-case I make some mistake.
Before I used live in HAL area where all the broadbands were available and i had BSNL with the 750 plan, I was quite satisfied with it.
Recently, I moved to a new area, AECS Layout Block B,Singhasandra,Bangalore-68(Check it out on G-maps).... Well the first shocker was that in this area there is no company which provides internet till date(Not even BSNL :nonchalance: )
So i had to out of my way and buy BSNL 3G and Relance Netconnect... Both give good speed(Full signal for both), with 5 GB limit...
Recently I came to know about BSNL evdo from their site and it says its truely unlimited(YES, I'm fed up with the 5 GB limit, since if actually enter something like YouTube, Poof! 5 GB's Gone in 3 Days)
So here are my Queries:
1.I get full signal strength in BSNL 3G and speed ranging from 5-7.1 Mbps i.e 500-710 KBps download speed(My device itself can handle max of 7.2 Mbps)... So will I be getting the same signal strength and download speed? (i.e 1-3 Mbps-Since evdo gives max of 3.1 Mbps)
2.Any router you suggest that i can put the sim into and it gives me wifi directly?
3.How do i test BSNL EVDO without spending much money?
Thank You guys so much in advance.. Pls. reply fast... I also need time to convience my parents to buy EVDO again... Also it would be nice if you could pm me some ISP that provides internet in this area leasantry:
