Anyone else in the Kolkata area getting this ?
Attenuation Up/Down: 3.5 dB /23.5 dB
SNR Up/Down: 18.1 dB/28.5 dB
Lost packets, wildly fluctuating latency.
If there are too many packets i can completely disconnected from the internet. When this happens and I try to dial into bsnl i get the "the remote computer did not respond", or "the remote computer took too long to respond" error.
I'm running on windows XP.
Typical ping :
Reply from 218.248.240.20: bytes=32 time=432ms TTL=251
Reply from 218.248.240.20: bytes=32 time=230ms TTL=251
Reply from 218.248.240.20: bytes=32 time=302ms TTL=251
Reply from 218.248.240.20: bytes=32 time=215ms TTL=251
Reply from 218.248.240.20: bytes=32 time=350ms TTL=251
Reply from 218.248.240.20: bytes=32 time=360ms TTL=251
Reply from 218.248.240.20: bytes=32 time=211ms TTL=251
Reply from 218.248.240.20: bytes=32 time=275ms TTL=251
Request timed out.
Reply from 218.248.240.20: bytes=32 time=274ms TTL=251
Request timed out.
Reply from 218.248.240.20: bytes=32 time=296ms TTL=251
Request timed out.
Reply from 218.248.240.20: bytes=32 time=179ms TTL=251
Request timed out.
Request timed out.
Reply from 218.248.240.20: bytes=32 time=306ms TTL=251
Reply from 218.248.240.20: bytes=32 time=471ms TTL=251
Request timed out.
Reply from 218.248.240.20: bytes=32 time=560ms TTL=251
Reply from 218.248.240.20: bytes=32 time=225ms TTL=251
Request timed out.
Reply from 218.248.240.20: bytes=32 time=223ms TTL=251
Also, i get this problem only at certain times of the day, most notably during the nighttime unlimited period
Typical ping :
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
