dishtv_info
Regulars
hi guys,
does any one give suggestion on trouble shoot this one.....
it was showing this one
301 signal not found
cheak if the connectors are properly connect to the stb
I have called cc they told to switch on and off the stb i have done that but did not worked
so when to the stb setting there i found these information
signal lock :no
signal Strength: 0%
signal quality :0%
does any body experienced this problem during monsoon so please let me know
trouble shooting details
I was checking this details on other section about this problem there i found that TS is getting 150-160 signal strength at normal conditions so during monsoon it will be around 60-70 that dishtv offers during normal conditions
just post any may troubleshooting technies
My 1st question is
1)why its only during monsoon ?
2) If its the cloud cover or rain gauge betwen satellite and the receiver as per the any DTH problem then can we put amplifier to boost the signal through ?
if so then specify the type of amplifiers ...
signal lock :no
signal Strength: 0%
signal quality :0%
My 1st question is
