Ethernet cable quality may affect speed of the internet?
  • Thread starter Thread starter vinothkrm
  • Replies Replies 3
  • Views Views 2,418
vinothkrm
BSNL
Hi friends,I'm using BSNL Broadband 750 plus. unlimited down/upload, 256 kbps speed. i'm using low quality ethernet cable connectivity to use net access.download speed is vary from 25 to 30 kbps only. my friend said that change the quality ethernet cable.it will increase speed. i dont know it is possible or not.i want to know if i change ethernet cable, speed will increase or not.Thanks in Advance.
no.. wont make any difference. ethernet cable are capable of carrying MBs of data per second. Poor cable can carry data slowly but when speed is anyway very slow, it wont make any difference as even poor cable wud be sufficient to carry data at that speed.
yeah, it doesnt affect the speed... BSNL is always slowIt would be a better option to check ur speed in speedtest.net and if the speed is not satisfactory then call the Customer care... i know the BSNL CC sucks but, give it a shot..
