Excitel Broadband Ethernet Cable is LIVE!
you would need to find a screw that fits in that hole though. it does not come with it which is idiotic. took a while to find something that fitted it perfectly.
will it help if I add a cheap router instead of a surge protector?
Excitel provided a cheap Tentis router, which I won't use for wifi.. so can I use that router to connect WAN input from Excitel and then connect one of ethernet port to my network (other routers/load balancer)? In case of lightning or current leak, I hope only the cheap router will fry and rest of the network remains safe?
