Excitel Upload speed issue
  • Thread starter Thread starter Vickey007
  • Replies Replies 47
  • Views Views 7,258
speedtest (IN): Speed Test - Broadband Internet Speedtest - speedtest.net.in
speetest on airtel (seedtest.net)
what is I did noticed is, on peering sites I am getting full 300 mbps while downloading but other than that I not getting speed anywhere.
I also noticed that if on speedtest.net.in i am getting 50 mbps then I get max 50 mbps download speed other than peering sites such as usenet/torrents
I get booted out everytime on 4-5GB quick download or upload.
Have reboot ont to get back.
Have noticed this on one drive ul and now torrent dl too.
Not sure where is problem, if ont get hot or lco has put checks.
Changed primary isp to Airtel fiber now.
Gonna use this for full download to see when they terminate my connection.
@igloo this happens at specific times or everytime ?
Might be some issue related to buffer bloat in ont .
Are you using bridge mode ?
Switched to Airtel 100 Mbps last week, had Excitel 300. From 1st May till 8th (stopped using beyond and my sub ended 13th) exactly at 7 PM - 1 AM in evening download used to fluctuate b/w 2 Mbps - 6 Mbps. Phone support is down, chat support is useless and LCO was passing bucks to Excitel - I was frustrated. I'm from 110053.
I myself is waiting for Airtel FTTH to be available in my location. But sadly they have no mood to give fiber at the movement.
Excitel is becoming worse day by day.
Is Excitel becoming worse day by day or LCO is not gud or it's area specific issue.. planning to go with Excitel so asking the question.. thanks in advance
Excitel is LCO based and LCOs due to current demand and supply factors in market are abusing their market power by making insufficient investment in infra(mostly in fiber cable) and over-subscription.
Earlier LCO atleast used two core fiber cable(two obtical fiber strands) , nowadays some are just winging it with one cable. (JIO in comparison uses humongous 98 core purple cable)
Lastly Excitel is not good if you are using international bandwidth or anything not on peered networks or any plan beyond 100 Mbps
  • Wow
Reactions: Smh
I dont think single fiber would be that much a problem as single mode fiber has huge bandwidth capability. I might be wrong though.
If using single fiber core , lco must be using splitter to give connection which would reduce the power level for ont too.
I suspect low grade low bandwidth olt might be the issue if speeds are reduced because of oversubscription.
