Fed up of FUP - Migrating to BBG SPEED COMBO @ 2799 - 8Mbps - 60 Gb
  • Thread starter Thread starter rsatbf
  • Replies Replies 56
  • Views Views 6,354
Roaming is free. Get a 7.2 Mbit data card. Bsnl mostly has HSPA+. But do check the signal strength at your place. Also, in order to get an MTNL sim, you need a residence proof of Bombay. Also, where did you complain about your speed issue ?
This is great! My brother is going to Mumbai next week and can pick it up for me. What speed do you get sir?
Hmm looks like the roaming is not free and I am from Chennai :(
Also this is a 3.6Mbps datacard.
Trust me..If you can get a MTNL 3G SIM..get it..Hook it on to a router and spread the 3G vibe all over the place...I would strongly recommend you try this.. :)
Doing this for over a year now..Just check the 3G signal of BSNL at your place...If you are lucky enough you might get as high as 7Mbps!!
Will give it a shot. I have a BSNL 3g SIM in my iPad. Will check the speed on that first.
On my 8Mbps I got this once or twice
However, took me a lot of struggle and visits to BSNL JE, AE, NIB and some number where the AE didnt want to waste time calling as he needed a smoke. However it seems to have worked and I am now getting more than on my previous 4Mbps connection, though not by much or consistently. I am mostly still under 4Mbps most of the time, but thought would share an update.
Make sure to get a MTNL 3G Postpaid SIM!!
Are you using the MTNL 3G Datacard or SIM? And are you using this in Chennai/out of Mumbai?
I'm using it in Pune currently...But i'm sure you would get around 5Mbps....Just make sure you get a postpaid connection as the plans have been revised..and there is no UL plan in prepaid connection!! not anymore..but its present in Postpaid!!No roaming charges...I'm using it both in my mobile and Datacard!! I Get about 600Kbps download speeds!! :)
