forward port on default gateway 192.168.1.1
  • Thread starter Thread starter xsqueezme
  • Replies Replies 10
  • Views Views 4,981
No you are correct and gateway can also be called as routers, since they are technically the gate keeper between you the lan and the internet.
Some routers do not allow certain services to be run or exposed to internet as a security measure.
When you buy a third party routers and are using it as the main gateway, it does not come with such limitations.
