Found a way to check 3G balance and validity using USSD command (Mumbai)
  • Thread starter Thread starter sanke1
  • Replies Replies 8
  • Views Views 7,241
Mumbai
MTNL
Dial *446# from your Mobile handset. You will receive 1-2 SMS with all the balance info. You may receive USSD response if you have recharged recently. Works in Mumbai. Not working in Delhi as of yet.Finally MTNL hai to Sahi hai.
Doesn't *444# perform the same function ?Edit - Nevermind, *444# gives information about account validity only.
*446# unfortunately doesn't work in Delhi " Operation Failed "
I always use this to get data information.*444# displays balance and sends information about data via SMS.
You will receive 1-2 SMS with all the balance info. Works in Mumbai. Not tested with Delhi.
great work..!! :D
can you update in your post in MTNL User Experience Thread..!!
now only if we could have something like that for BSNL, also my problem is I dont have dialer ( using tablet) so anybody knows how can I send a message and get back the answer on BSNL ? I know for Docomo it is simple as sending BAL to 121 and it sends you SMs with everything
