No! If you install an external gpu. It 'll be priortized. You processor gpu 'll not have any use.
Btw, how did you get a different mobo as a replacement? If the old had the D-Sub or any port to connect the display. you should have got the same mobo.
Thanks for your help!
My old board was P7h55-M. It had on board graphics. Now these are old boards LGA 1156 sockets (completely obsolete). Even getting a new board with LGA 1156 socket is almost impossible. I wanted a board with LGA 1156 so that I can use my processor. The best they could find was this.
Thanks!
You should have asked for motherboard supporting ivy bridge cpus , instead of spending 2k on a graphics card you can spend 3k on a new ivy bridge pentium dual core intel cpu & sell the old cpu for 2k on olx or techenclave , you get free upgrade to current gen cpu/board .
