[Guide] How to host webservers on Jio Fiber, accessible to IPv4 clients
  • Thread starter Thread starter poiasd
  • Featured
  • Replies Replies 89
  • Views Views 45,639
As you might know, Jio does not offer static IPv4, and it is not easy to apply for port forwarding (for Camera etc. purposes). However, they do provide IPv6 and this can be used for hosting web servers.
To allow IPv6 incoming connections to your device (e.g. a PC running nginx), you need to disable all firewall rules in Jio Router. (At least initially for ease of setup / troubleshooting - once you get it working you can slowly tighten it up).
Your device on which you want to host must be connected to your Jio router directly (Wifi or LAN) and must have IPv6 assigned from the Jio router's DHCP.
On your device running webserver (nginx, plex, whatever), make sure it is bound to localhost or the IPv6 equivalent (NOT 127.0.0.1 - this wont allow IPv6 connectivity). Usually apps bind to all network interfaces so you should be fine.
From command prompt (or equivalent), Type ipconfig all (if you're on linux you probably know the commands - but it should be ifconfig), and view your IPv6 address. This is indeed your "Public IPv6". Let us assume it is 2001:0db8:85a3:0000:0000:8a2e:0370:7334
If your server is running on port 80, for example, you can now, from another client, access it by specifying a URL [2001:0db8:85a3:0000:0000:8a2e:0370:7334]:80. But this is limited to IPv6 clients only.
For IPv4, you need a domain name. Freenom offers free '.tk', but I'd recommend spend $1 and get a .xyz or something from namecheap. With a domain name, you can setup a cloudflare website, and have the DNS AAAA record point to your IPv6 (no A record).
E.g. AAAA record for 'randomdomain.xyz' -> 2001:0db8:85a3:0000:0000:8a2e:0370:7334
Set cloudflare proxy for the domain to "On". Now cloudflare will act as an automatic gateway, and IPv4 only clients can go to randomdomain.xyz, and access cloudflare over IPv4, which itself will connect to you over IPv6.
Using this method I was able to run a webserver, and had a friend in U.S. download from me at ~90Mbps (My Jio Speed is 100Mbps). This was probably helped by routing over Cloudflares network.
One caveat is - you cannot run services like FTP, SSH etc over Cloudflare, only web servers (on port 80 and 443 only, too). But for hosting Plex or something it works great.
Have fun!
I checked your IPv6
1. Iam able to browse on port 82 - Webpage of openmediavault
2. Port scan shows the jellyfish port as being closed i.e port 8096
3.Following ports shows as open - ssh port 22, 139,445
4. 80 , 443, 8080, 8096 shows as closed
To check I installed JellyFish default port 8096
1. http://[2405:201:7:c002:6591:deb3:7be8:ea8e]:8096/
2. I find it works from out side just fine, you can check the same
3. We need to now check from your windows PC or on the RPI if you can internally telnet to port 8096, 8080 and also browse internally - Does it work fine on the Ipv6 addrees either directly on the RPI or from another device internally?
Are you actually in Mumbai ? I just tried pinging your IP and the response was in around 60ms, which is quite surprising as every single Mumbai server generally responds in 90-120ms.
Yes from Mumbai. I get around 60 ms if I go via airtel. Which ISP are you using?
just fyi its hosted on a macmini , in case that makes a slight difference in response time’s
Yep, I can browse jellyfin internally using ipv4 not ipv6 and I can access your jellyfin server.
Note that my jellyfin is on docker
1.You need to get it working internally first using ipv6
2. Your issue therefore has nothing to do with connecting from outside.
3. You should mention everything that is being used in your setup.
4. Docker is a container and running in isolation. You need to enable the ipv6 Dameon in docker.
Has this been enabled? .
5. First check internally using ipv6 , if it works then only can it work from outside.
Bro I'm also using JioFiber. Ping is very high in my area(Jharkhand) for every server because the ping on the gateway(Asansol/Kolkata) itself is 30-40ms. Still it's surprising to see 60ms ping if you're in Mumbai. I'm guessing that some of their routes are IPv6 only due to which my IPv4 traffic has to take some other route to reach Mumbai.
30-40 ms to your gateway? That is very stupid of Jio given that I am getting 1-2ms compared to mine from Kolkata.
This reminds me of the time when ADSL connections existed where Airtel's gateway itself was 40ms so pinging any IP would add 40-50ms because of the idiotic routing from the gateway to the destination address but that had also got fixed (stable at 3-4ms) as soon as it changed to a VDSL from an ADSL.
Here is an example of a traceroute to 1.1.1.1 (IPv6)
Tracing route to one.one.one.one [2606:4700:4700::1111]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 2405:201:800a:xxx:xxx:xxx:xxx:xxx
2 * * * Request timed out.
3 3 ms 3 ms 2 ms 2405:200:801:500::1d
4 3 ms 4 ms 3 ms 2405:200:1606:600:49:44:187:2d
5 3 ms 2 ms 3 ms one.one.one.one [2606:4700:4700::1111]
Trace complete.
Can you share your traceroute/tracert result here to [2606:4700:4700::1111] which is the IPv6 address of one.one.one.one
Tracing route to one.one.one.one [2606:4700:4700::1001]
1 2 ms 1 ms 1 ms ROUTER_IP
3 29 ms 29 ms 29 ms 2405:200:801:500::1d
4 26 ms 24 ms 25 ms 2405:200:1606:600:49:44:187:2d
5 24 ms 26 ms 24 ms one.one.one.one [2606:4700:4700::1001]
Trace complete.
This is the IPv6 traceroute and the IPv4 one is:
1 1 ms 1 ms 1 ms reliance.reliance [192.168.29.1]
2 5 ms 4 ms 5 ms 10.27.208.1
3 27 ms 27 ms 27 ms 172.16.89.153
4 30 ms 31 ms 31 ms 172.26.66.54
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 76 ms 106 ms 74 ms 103.198.140.164
13 117 ms 116 ms 117 ms 49.45.4.82
14 118 ms 119 ms 119 ms 103.198.140.49
15 111 ms 112 ms 130 ms 162.158.160.241
16 117 ms 117 ms 116 ms one.one.one.one [1.1.1.1]
I'm ignoring 10.27.208.1 and considering 172.16.89.153 as the gateway for IPv4 as one of my friends in a nearby city has the same traceroute beyond the 2nd node. Surprisingly 8.8.8.8 and dns.google(IPv6) also has a difference in ping.
Yes Its possible. Are you hosting gaming servers that you need low ms ?
Yes I play online games and need low ping.[Connection through other ISPs could give me 40ms for Mumabi]. I've tried complaining but nothing improved.
