Good Quality Signal settings for cable modem
DownStream / Recieve Power Level - -8 to +14 dBmV
DownStream Signal Noise Ratio (SNR) - 32-40 dB (must not below 30dB will cause slow speeds)
UpStream Signal Noise Ratio (SNR) - 31-36 dB (must not below 29dB will cause critical slows slow speeds, No Connectivity, Late signal Detection, often modem drop out)
UpStream / Transmit Power Level - 45 dBmV & lower
Type in IE or Mozilla to see Modem Diagnostics if integrated
http://192.168.100.1/
Cable Modem Diagnostic
Cable Modem Diagnostic is simple program for remote measuring of basis parameters of cable modems. Support DOCSIS standard.
Download
http://www.patilan.com/cmd.exe
just in case if appears to not working open browser hit 192.168.100.1 2-3 times run program again
If Your Signal Levels Fine
Still Getting
Slow Speed, Delay in Modem Coming online
Weird Signal Problem like Cable & send light flashing but no receive
even tough signal levels fine
It is Upstream / Downstream Frequency Channels Problem
Imagine you are watching picture on your set top box & that channel is lagging too much
If that Happens with Internet Channels what will happen?
Right
On browsing you will have to refresh often
On downloading your download will start lag start lag with download acceleration
without download acceleration download will start lag start stoped responding in middle
Download
Still Getting
Right
