Hathway High Ping Issue, Please Help
  • Replies Replies 53
  • Views Views 20,978
@Mr_mime Could you check the speedtests now and post the results?
DEN
ACT
Hathway (Yes, Hathway to Hathway also)
Thanks.
@Mr_mime You should check again. It shouldn't be usual.
It should be 60+ ms for every server.
Or if you could post screenshots?
It's more than 1 month now and there is no solution yet. They haven't fixed the issue. I have made multiple support tickets but they are not fixing it.
I am having the same issue with high ping. I live at Thane and the servers in Thane show really high ping like 160-170ms. I get the same high ping on online games i play like CSGO. This is happening past 2 months. It has happened before but got fixed automatically but not this time though. I have already tried every method possible i had to solve this but i just couldnt. Getting alot of hops on traceroute. Please help.
Didnt add that previously i used to get 10ms on every mumbai server
