Hathway's H-Fiber broadband and how it's better than most of the ISPs out there.....
Before I even start on how H-Fiber is better than other ISPs, let me throw some light on what it is actually.
Hathway's H-Fiber is a bit different than Hathway Broadband, or atleast that's the case in our locality (Kolkata). How? Let's see:-
1. Mode of transmission:
Hathway broadband is served directly from ISP's local node to the customer's premises. There is absolutely no involvement of any Local Cable Operator in any way. However, H-Fiber is served via your local cable operator.
This means, if your LCO is a shitty man, you're bound to experience a shitty fibre broadband connection.
2. Medium of transmission:
Hathway broadband uses Coaxial/Ethernet/Fibre in many places. H-Fiber, as the name suggests, is a pure Fibre-to-the-Home network.
3. Websites, login pages and all that...:
Hathway broadband's website is www.hathway.com and their account login page is ispselfcare.hathway.net .
H-Fiber's website is hfiber.in and their account login page is hfiber.in/CustomerPaynow/Frmcustomerlogin.aspx .
Also, Hathway customers get an app for mobile and a free router (depending on availability). We don't get any of that.
4. Plans and pricing:
Following is a snapshot of Hathway Broadband's Plan for Kolkata:
Following is a snapshot of the pamphlet provided to us by the LCO:
Comparing both, there is a very little price difference. The major difference would be that, Hathway's Connection has FUP, H-Fiber is truely unlimited.
Now, enough with the comparison. Let's see why it is better than the rest....
Reason 1: All ports are open.
Yes, you read that right. All ports are open in H-Fiber. And by all, I mean all, be it port 25, 80, 443 or something else. Here's a snapshot from canyouseeme.org:
Reason 2: Symmetric Upload and Download Speeds
Some ISPs in kolkata, such as Alliance, offer non-symmetric speed. Like for example, Alliance broadband users get a Down speed of 60 Mbps and an Up spped of 15Mbps. Such is not the case with H-Fiber. Download and Upload speeds remain the same, always.
I use the 70Mbps plan for Rs. 700/- (excluding GST).
Reason 3: Dynamic Public IP Address Allocation
The IP address assigned to you will be a dynamic public IP, meaning that you can access your system from outside with your public IP only. Another way to say this, the value of "What is my IP" in Google Search will be the exact IP address that your router will have on its WAN port.
Reason 4: Supports Cloudflare's 1.1.1.1 DNS
Some users complain about their ISPs blocking 1.1.1.1, or even if you use 1.1.1.1, your data gets routed through ISPs DNS somehow. Such is not the case with H-Fiber.
Also, after changing the DNS IP, you won't have to face the problems of sites getting blocked, as we get to see in Jio's infamous sanskari firewall. This means you can access most of the torrent sites and some other sites (if you know what I mean).
Now, coming down to the cons....
1. Connection through LCO.
2. Customer care knows nothing about plan pricing. Whatever the LCO will tell you, you'll have to blindly accept that. For example, I wanted to buy a static IP from Hathway. But, on contacting them, they told me that you'll have to buy it from LCO, and that they can't help with the pricing either, as they don't possess that kind of information.
Other than that, its mostly a stable connection.
I'll highly recommend this H-Fiber connection to anyone in Kolkata, as I think it's the best we can get till now. Also, I think the plan pricing will be slashed soon, once the Jio GigaFiber commercial roll-out begins.
P.S: Since majority of Hathway's shares are now owned by Reliance, I think they're gonna give similar plan pricing.
I am open to all kinds of questions and queries regarding this connection. Ask any question I'll try my best to answer them.
Anyone from south/tamil nadu using hathway fiber? please post ping results. I am looking to switch.
I got the connection few days ago. I am from Vellore. 100down/50up 700gb/month Rs.1177 for two months.
I have a hfiber broadband connection in my laptop directly from the ONT. How can I share this internet connection via mobile hotspot or in any other way without installing a router at my home? Please reply and show me a way to achieve the above.
If you have a laptop that's not that old then this method will work.
If the above-mentioned method doesn't work then try,
Im am from chennai, I want a static ip with all ports unblocked as i am going to run game servers. Which broadband is good for this? Also can someone send me the link for hathway hfiber chennai. Im unable to find it
Hathway provides normal fiber connection in Chennai.
Hathway does provide static ip on extra charge.
Fill new customer form in Hathway website they'll contact you
@vignesh_venkatesan,
I contacted their new customer no. I talked to a sales person and after a while i finally talked to a person who know what im talking about, he told me 20% of ports will be blocked.
Are there any alternatives? I have tried cherrinet but it has had some downtime and it is 2400rs per month + 5000 for static ip all ports unblocked.
And is Hathway H-Fiber different from Hathway noraml fiber?
Also does anyone know where i can buy 2nd servers and hardware firewall?
Thanks in advance
H-fiber is just a marketing term of Hathway where they had coaxial based broadband.
Chennai is a pure ftth city for Hathway, so they're will be no difference.
Regarding ports, common ports might be blocked on a resedential connections, usually getting static IP will give you open ports.
In my locality (Kolkata), there's not much difference except unlimited data and all open ports. Also, Hathway line is served directly from local node (like Airtel), and hfiber via LCO.
I'm not sure if 'H-Fiber' is available in all locations. As far as my knowledge goes, I think they're available only in kolkata.
