Help For Connecting 2 Dsl Lines
  • Thread starter Thread starter humtum
  • Replies Replies 12
  • Views Views 4,138
humtum
I have two telephones .One is Nu and other is dsl 399Is it possible to connect both the dsl lines at the same time to my pc to achieve a browsing speed of 512?I am not in the techi stuff, plz give me the steps to connect both the dsl line to single pc.
Hey man i have the same question, i am planning to have 2 diff connection froms 2 diff isps..both dsl. only have 1 lan card..do i need 2 lan cards for the pc..and how can i configure the whole damn thing. bear in mind i will be having 2 dsl modems..
chill man, if nobody replied to ur post, then its because they didnt know the solution to ur answer.. being sarcastic doesnt help either, it aint like ppl are paid to help u.. as for ur question, i found this while googling on the internet...
http://www.theinquirer.net/default.aspx?article=13103
i doubt however, that it is available in india.. you could order from the internet or something
you can.. just bridge both connections together. ;).. in network connections.. you got the option to do that... you can browse at 512kbps.. dunno abt downloadin though
bridging will not do wat he wants.. to multiplex two connections, you need a hardware product like the one in the link i have posted.. how would you combine two network connections that have different hops to the same distance? you should research something before just posting it ;)
i did research da sh*t dont need be sarcastic son.. hhmmm, i think the double bandwidth that would come into play using winproxy would require multithreaded downloads.. it still aint combining the two connections.. just load balancing them.. bridging wont work thoughthe bandwith of the second modem would only come into play when browsing two webpages for example.. u CANNOT combine two connections into ONE fat pipe like this
