You have to follow this step for installing puppy linux installation:
1. Download Puppy linux ISO and burn the ISO to CD.
2. Start your computer via the Puppy CD.
3. Once Puppy has loaded, from the Taskbar, Click: Start > Setup > Puppy universal installer.
4. Follow the onscreen instructions which will walk you through the Puppy USB installation process.
5. When finished with the Puppy USB install, reboot your PC and go into system BIOS to change your boot order to boot from the USB device.
6. Save your settings and reboot your PC to enjoy running Puppy Linux from USB.
My Friend,
I already mentioned that CD ROM is not working and PC does not support USB boot.. :wall:
