1.Confirm you are getting connected to Internet in "Always On"
mode.
MT882==>> computer==.. Internet on
2.Start run type cmd type ipconfig /all
Post data.
3.Start/ Network/LAN/Proerties
TCp/Ip
properties
select obtain IP adddress automatically.
SAVE apply.
4.Mt882==>>grandstream== computer
can you access the Ip of grandstream ?
or 192.168.1.1
5.1. Connect a standard touch-tone analog telephone (or fax machine) to PHONE port (or PHONE1,
PHONE2 port for HT386/496/502).
2. Connect a PSTN telephone line to LINE port (optional, applies to HT386/486/488/503 only).
3. Insert the Ethernet cable into the Ethernet port (HT286/386) or WAN port (HT486/488/496/502/503) of
HandyTone and connect the other end of the Ethernet cable to an uplink port (a
router or a modem, etc.).
4. Connect a PC to the LAN port of HandyTone (optional, applies to HT486/488/496/502/503 only).
5. Insert the power adapter into the HandyTone and connect it to an electrical outlet.
6. Using the HandyTone embedded web server or IVR (Interactive Voice Prompt) menu, you can further
configure the phone using either a static IP or DHCP.
Configuring the HandyTone using a Web Browser
1. From the analog phone, press *** to get into the IVR menu. Enter option 02 to obtain the HandyTone’s IP
address.
2. For HT486/488/496/502/503, please enable the “WAN side HTTP access” option by entering IVR
option 12 and press 9. A reboot or power cycle of the HandyTone is required after this change.
You can
also access the HandyTone’s web configuration from a PC connected to the LAN port via 192.168.2.1.
3. Type the HandyTone’s IP address in your PC browser.
4. Log in using password “admin” to configure the HandyTone.
You will need the following information to configure the HandyTone via the web browser:
1. IP address, subnet
mask and gateway IP if using static IP.
2. SIP server and/or Outbound Proxy FQDN or IP address.
REF:
Grandstream - Innovative IP Telephony
http://grandstream.com/documents/HTQuickInstallGuide.pdf
http://www.grandstream.com/user_manuals/HT502_User_Manual.pdf
