/members/kavishg786/
Give your modem details. Are you using Wanminiport dialer ( user ID and Password given externally. ,
or system is "always on" ( user ID and password entered in the modem )
I do not use torrents and cannot help you for torrents download/upload.
generallyAnyway by trying these programs you may increase the D/L speed.. Use Stardownloader DAP etc for downloading files/programs.
Best server to check D/L is
microsoft websites.
1.connection booster from trafficzapper.com
( recommended valuies by the program may be tried)
2.TCP/IP optimiser from speedguide.net.
Check the advice given by the test site.also.
3. Dr TCP usually used to adjust MTU, also can change other parameters.
Check D/L with each program at same server
at speedtest.net say mumbai server.
Eveytime you change the settings you may have to restart the computer.
Hope this helps. feedback will be useful to others.
i have ut - 300r2u
i use wanminiport.....
i have also got tcp optimiser
