Help pls?
bsnl broadband
I am thinking of changing my broadband connection plan to 750UL.What is the speed of 750UL is it getting 512Kbps or is it 256Kbps.I am now on 500cc plan with night unlimited.How will be the browsing speed of 750UL?Will the pages load quickly or will it take lot of time?I will download a lot using torrents and also one click hosters.I will also watch videos in youtube.Will 750UL load the youtube video quickly or will it take buffer for lot of time?Pls answer my questions.
speed may not be constant.
you can select Home 500 plans and unlimited download during 02-08AM using scheduler/s.
for speed upto 2 Mbps
With present speed You tube videos : are they buffered often ?
see full details here.
Bharat Sanchar Nigam Ltd.
I am on 500plan with night unlimted I am getting huge bill as I dont have control over my browsing,so I am thinking of changing my plan to 750UL.how will be the browsing speed if I change my plan?Will pages load quickly as they are loading in 500cc plan.
I am using UL 750. I get 60 - 70 KBps on good server. YouTube is working fine. It has a bit of buffering but quite watchable. Expect a speed of 55 - 60 KBps on good torrents, link-removed and similar. It quite suits you if you are fond of browsing. I use it because I browse a lot. With its renewed speed now 512 Kbps it is easy to download also. Be warned ! shifting from Home 500 to UL 750 will certainly upset you for a few days as there is a considerable difference in speed. But overall it is a good plan and a good bargain.
Nett usage - Allowed Limit for this plan
3945.17 MB - 2560 MB
1385.17 MB
these are my current stats what i used till now.
I will apply for a plan change tommorow what will be my bill in the next month if i get unlimited connection on 21st august.
how they will calculate if i change my plan in the middle of the month?
@meetdilip :are the pages opening quickly while browsing like in 500cc plan?
---------- Post added at 06:27 PM ---------- Previous post was at 06:24 PM ----------
what is the upload speed is it 1/4 of download speed?
बहुत अच्छी है... मै अभी ये ही प्लान इस्तेमाल कर रहा हू.
सच बोलू तो फरक पता भी नहीं चलेगा
भाई मेरी मान तो 750 प्लान ले ही ले. रात को चैन की नींद ले और दिन भर बैठ कर आराम से youtube विडियो देख और जी भर कर torrent से downloading कर
UL 750 is changed to UL625. This change is for Andhra,Gujarat, Punjab Home user only.Free calls- 100Speed- 256 KbpsDefinetly the speed is Less compared to 500C plan
Free calls- 100
Speed- 256 Kbps
no there is other plan ul625 which have speed of 256kbps
ul750 will get speed of 512kbps
this is what mentioned in the bsnl website.
I had applied yesterday for my plan change when is it going to change?next month or in next fewdays.i have read few posts they said their plan changed in 2 days is it correct?
