Help required to configure landline with Digisol DGGR6011 on Airtel fiber
  • Thread starter Thread starter rajput
  • Replies Replies 2
  • Views Views 70
Delhi
Airtel Fiber
Hello,
I need help with settings to configure landline on Digisol DG GR 6011 with Airtel fiber.
So far I have managed to change serial number and get internet working by creating vlan 100 settings.
I have created vlan 660 settings but telephone is not working.
Airtel supplied ONT is Nokia 2425A but it is locked down and there is no option to extract cfg file to read settings.
Airtel support is acting stupid as usual. They said internet will also not work but it did, now they are saying telephone will not work.
NOC team only knows how to push settings via TR069 and nothing else.
I hope community will help.
Did you use Telnet to change the serial number? And what’s the username and password for Telnet?
I was able to setup telnet in latest firmware also. You have to set firewall settings to low then select security login privilege for telnet and http enables on lan.
Connect via telnet and (disable antivirus which will block telnet)
#flash set PON_VENDOR_ID HWTC (this is for Huawei) I used ALCL (from my Nokia modem)
#flash set GPON_SN HWTC00D81758 (last 8 digits from your modem serial number)
reboot and voila! serial number is changed and it will register on Airtel Fiber.
User and password same as you use for login.
