Quote:SRReddy from vinuthomas.com This worked for me!!!!!Recently bought this router. There r two things worth pointing out which may give u trouble in configuring if u r not aware. 1. By default, in the MAC Address menu in wireless, White list option is enabled. So, unless u enter the MAC address(es) of your device(s), u will not get connected. Alternately, u can disable this option. 2. U have to enable the wireless to get connected. By default, it's disabled. This fact however, is mentioned in the instructions leaflet that comes with the router.I spent a lot of time to discover that MAC Address White list is enabled by default as I was not getting connected after the usual config & BSNL people had no clue about it. They came & simply said they have to find a solution because it's a new router.
