Help ! Sify 256 Connection Sharing Thro' Router
  • Thread starter Thread starter yessgee
  • Replies Replies 1
  • Views Views 2,355
yessgee
Regulars
BSNL Home 750 UL
I am planning to install a Netgear RP614 router to connect to my 256 Unlimited SIFY BB connection, from two PCs, either individually or simultaneously. I was earlier sharing the connection through a crossover cable with two NICs in the first computer to which is connected my SIFY LAN Cable. But the crossover mode necissates me to keep the first computer switched on as long as the second computer is used for internet. To overcome this, I am proposing to go for the router. Can somebody suggest me as to where the BB Client is to be loaded with router in place such that I can login from either or both of the PCs.Thanks in advance.
