Hi Socrates,
As you said I'm trying to connect to the internet using only Sterlite modem. The settings as I have posted in the link above. Still I'm unable to get the
adsl signal.
How shall I check SNR Margins & Line Attenuation?
The Ipconfig/all as below.
Connection-specific
DNS Suffix . :
Description . . . . . . . . . . . : Broadcom
Netlink (TM)
Gigabit Ether
Physical Address. . . . . . . . . :
Dhcp Enabled. . . . . . . . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.2
Subnet
Mask . . . . . . . . . . . : 255.255.255.0
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 203.94.243.70
59.179.243.70
Ethernet adapter Wireless Network Connection:
Intel(R) PRO/Wireless 3945ABG Netwo
IP Address. . . . . . . . . . . . : 10.10.0.101
Default Gateway . . . . . . . . . : 10.10.0.1
DHCP Server . . . . . . . . . . . : 10.10.0.1
DNS Servers . . . . . . . . . . . : 10.10.0.1
192.168.1.1
203.94.227.70
Hi essbebe,
First I'm tryig to connect to internet using only Sterlite
router, but I'm not being able to do so.
Here are the answers to your queries:
1.Set up SamAX300 in "Always On" mode. Yes
2.Enable DHCP in modem Yes, done
3. test computer is connected to Internet. Not connected
Hi Socrates,
As you said I'm trying to connect to the internet using only Sterlite modem. The settings as I have posted in the link above. Still I'm unable to get the adsl signal.
Description . . . . . . . . . . . : Broadcom NetLink (TM) Gigabit Ether
59.179.243.70
Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Netwo
192.168.1.1
203.94.227.70
Hi essbebe,
First I'm tryig to connect to internet using only Sterlite router, but I'm not being able to do so.
Here I'm trying to connect to internet using Sterlite in PPOE LLC mode first.
No problem in the line. The MTNL perosn came in the morning & checked with other modem (white one) he got the ADSL link easily. So I changed the modem. But the problem persists. Now first I'm trying to connect using only PPOE.
Hi,
Am I missing any configuration parameters in SAM300AX?
:huh:
