[Help] Unable to access web using MTNL 3G + ZTE USB Modem
  • Thread starter Thread starter Sid
  • Replies Replies 56
  • Views Views 7,517
LOL i just started using it today only. getting speeds upto 300kbps in IDM. Going to sleep, will download stuff 2morow.
1650 for 200GB, dont forget hehehe
Do you mean I can get the SIM card from any local shop and recharge it with Rs 1650 either online or offline..
..and am good to go?
Yup :)
BTW, you may want to have a look at Asus 3g routers.
Sanchaar Haat would be your best bet, also, there are loads of shops which stock mtnl sims, not just the ones mentioned in the list.
Btw i am having problems with torrent downloads, whenever i try to download something (private trackers) speeds get low, not even getting 1kbps and i cant browse. Can only download torrent if i use VPN.
Samm buy you sim only from sanchar haat. They will activate it there and then and will recharge it too. anant had a bad experience through dealers.
Actually I know a guy who runs a mobile recharge shop nearby.He keeps Trump cards so, I am going to check with him :DI read in the forum that by default the data rate is capped at 384kbps and has to be upgraded to 3.5G, is that still a headache?
How far is sanchar haat from your place.... i would suggest not to risk on dealer. Moreover there is no speed cap thing in delhi circle. What i did was1. Bought the USB modem2. Bought sim for Rs 49.3. Bought recharge worth Rs.4500
