Can any body explain when you install jio fiber in your home, in the my jio app, there is option of jio fiber home gateway>wifi settings> .. then there are options like 2 nos - 2.4 ghz & 2 nos - 5 ghz. So my question is when you install for the first time, 1 each 2.4 & 5 ghz are active and other 2.4 & 5 ghz ssid are off/disabled. So, my question is what are those means? Does all of them has same passwords which comes in the back of router? Can we disable 3 of them and use only 1 ssid?
