Isn't the Reliance an ADSL connection? So an ADSL connection + ADSL2+ router should work just fine, right?
works with n router.... not with ADSL router
and yes. adsl connection ...
once u connected router with reliance line it will not let u open router setting page ... so it hard to for any normal user ... if u want to pull ur hair go ahead and try it ..... or buy new basic router
Yeah. But, you can assign your system a static IP and open up the settings page.
o know what i done ...but once you use any static ip u will loose connectivity ......and hey just ask any one here they used ADSl wifi router with reliance ...without problem .... or pull hair from head ..
,,,and if u connect router ...any how... but u will not use it on any other device ... because u have to close DHCp server on lan for connecting and for getting ip from reliance
Quick question, I don't see any MER setting in my Router's config page. The Reliance connection will work fine on pppoe right
reliance not working on pppoe or any thing .... or any thing ... just works on DHCP wan server ( bridge connection )( not sure ,no one really know how reliance works )
It should work technically all ADSL modems are PPPOE and bridge switchable..atleast mine is...UTSTARCOM WA3002G4...the only thing that would be odd is the firmware in it...but as the line will automatically generate a static login page everytime...in this you will have to put that address in the address bar....Lets see i'm gonna try this out..
