Help with TP-Link XZ000-G7 Gigabit XPON Terminal Configuration for BSNL FTTH
  • Thread starter Thread starter RajaTamil
  • Replies Replies 57
  • Views Views 7,630
Can anybody recommend which ONU to get for BSNL fiber? or is it possible to enable bridge mode?
@lordxavier78 I pivoted from Airtel - BSNL, opted for the DG-GR6011.
Do ask LCO if his stuff is on GPON/EPON. Mines on GPON so G3V1 would also work, but cant think of reasons why you'd really wanna opt for it vs G7 since you'll get the VLAN.
DG-GR6011 has Telnet, so you can look for VLAN that way too. (I dont have much expertise here but this is what I read)
You get one already so doesnt really matter?
Btw, to start with, I'd advise you to just take the simple route.
I got my connection started, and I was able to Bridge 6011 and dial in PPPOE successfully without needing to Clone MAC in my case.
But even after disabling TR069, the default config which might be on the OLT get pushed to my ONU.
Which is no big deal since my LCO will setup Bridge asa we get my Static IP sorted.
So I'd just advise get the Whitelisted ONUs unless you want to FAFO with the GeeThree stuff right in the start.
Put that 6011 in Bridge and enjoy. Will make no difference.
@lordxavier78 I took my connection back when there was no authentication of any kind from the LCO or BSNL. The issue you might face now is WAN MAC address authentication which can be reset with a phone call to the LCO if cloning the MAC address doesn't work.
