'm having an issue with IPv6 on my connection. Details below:
Device: Netlink HG323DAC (2GE+1POTS+WiFi5 XPON HGU)Firmware Version: V2.1.08-250310Hardware Version: V4.1PON
Issue:WAN IPv6 connects fine — the router gets a valid global IPv6 address via PPPoE(confirmed working: I dialed PPPoE directly from Windows and got a proper IPv6address that way too, so the ISP-side IPv6 service itself is fine).
However, devices on my LAN (PC, phone, etc.) never receive a global IPv6 address —they only get a link-local (fe80:
address. I've confirmed via packet capture /netsh route tables that the router is not sending any Router Advertisement (RA)packets on the LAN interface at all, even though:
This looks like the RA/radvd service on the router isn't actually starting orbroadcasting, despite the web UI reporting the settings as active — possibly afirmware bug in V2.1.08-250310.
- RA Enable is set to "on" in Network > LAN > RA
- LAN Prefix Delegation is set to "WANDelegated"
- I've tried both SLAAC (AdvManagedFlag: off) and DHCPv6-Stateful(AdvManagedFlag: on, DHCPv6 Mode: Enable) — neither results in any RAreaching connected devices
- Full router reboots were performed after each config change
