mine is the same man fluctuates around 480 kbps.
I just spoke to airtel technical department and they told me on freedom 1699 1 mbps connection i am guaranteed minimum of 420 kbps.
I also inquired that if i change to freedom 2999 2 mbps connection what is the minimum upload speed im guaranteed and they said almost double around 800 kbps which is what bharat is getting on his connection.
Hey man !! Dont expect upload speed more that 70-80kb/s on 2 mbps plan of airtel . Airtel upload speed sucks .I am on 1699 plan and get upload very less.
I just spoke to another airtel cc since i have 2mbps business plan in my office and getting only 480 kbps upload speed. He says airtel only guarantees around 480 kbps upload if your getting more your lucky but we cannot guarantee that to each user.total crap now im reconsidering whether it is worth upgrading to freedom 2999.
my 2mbps connection gives me a constant 105 kbps using torrents
How do you get 105 kbps upload speed? Mine never goes past 45!
Its all luck man the airtel engineer who came to my office i had a long talk with him 5 mins back
. Airtel i believe even on 2 mbps plans only guarantees upload speed between 256 to 512kbps , if you get more like bharat and some others are getting theyre just lucky.
