hiiii m using Beetel 440TXI for my BSNL broad band...actually i was having airtel b4....now use...bsnl....bt in this there is very frequent loss of link light which leads to disconnections....so plzz helpThanks in advance...
/members/manind/Welcome to broadbandforum.coUnder Management client tr 069 disable it.Under Statistics/ ADSL post screenshot showing SNR/attn/line speed mod selected etc.
Open IE Type 192.168.1.1/main.html
ID admin Password password.
A menu page will open.
Go to Management. Select Client Tr- 069 Disable Save and Reboot.
( this works for Airtel connection/s) http://i21.tinypic.com/2njdq49.jpg
Device INFO Statistics /ADSL
sorry there is no such tab....its by the name of user managment in tht its shows the password thing..... sorrryyyy dude...i m not getting why dont u join me at [email protected].......
/members/manind/
No problem. may be in your modem/router this client. tr069 not available.
Open 192.168.1.1/main.html admin password.
Now type 192.168.1.1/tr69cfg.html If page does not open forget it.
Open http://192.168.1.1/statsadsl.html
Report data requested or post screenshot.
sorrry it says 404 page not found...
presume client tr069. page.
How about ADSL data ? You want to check your frequent disconnections or not ?
Giving negative input does not help , and other cannot also guide/help you without further information. There could be severe voltage fluctuations in your house also.
