No issue with jio sim, now I use dual sim on my redme note 3, all time 4g on and heavy usage, i dont fall short of battery whole day after single recharge
My battery used to drain at 1% per 2hours on 3G+2G combo now with a combo of 4G+2G it drains about 1% per hour even if I keep it idle with data turned off Normally I get above 90% signal reception on all my SIM
Have you guys observed battery consumption by App optimization and Android OS ? After using JIO with VoLTE enabled I am observing reasonable % of battery consumed by them.
