Was going to buy the TP-Link WR740N as suggested by @chaibiskutbhai but was also looking at the model WR720N which seems the same except that it has only 2 LAN ports and no external antenna. I have no issue with 2 ports. My only doubt is if the internal antenna will badly affect the range.
In my house in Pune, the range required is perhaps 30 feet. with 2 walls obstruction. In my Mumbai flat also the max range is the same but more walls.
Would the WR720N range be enough or should I not take a chance and go with the WR740N?
My reason for preferring the internal antenna is the cleaner look.
