Hi ..
Problem I am facing is of IPTV now.
1. I configured
ADSL to ppoep mode with phno and password. (DHCP enabled)
2. I configured DIR 524, with Dynamic IP (DHCP) starting ip 192.168.0.100. (DHCP enabled)
3. Wifi (
laptop) connecting successfully with 192.168.0.101...
4. when Set Top Box is powered on, it connects (7%)....loading...(58%),..... then after 83%... it says cant connect to server.
How to solve point number 4... do the IPTV ppl need to do some setting at there end?
OR
I need to change some thing in point 1/2/3?
congratulations.
Try only IPTV with the modem. Is it GLB or DSL 502 T /
then from any lan port of WIFI rrouter.
IPTV may be connected to 0 and 33 in MTNL ONLY In dialer mode. which vpi/vci you used ?
Untitled Document
Phone line ====>>> modem/
router LANport=====>>> IPTV SET TOP BOX ====>>
TV
( phone Internet as usual)
You cannot acccess IPTV via wifi mode.
REF:
http://www.calcutta.bsnl.co.in/iptvfaq.pdf
t
What is your connection speed ?
Feedback.
