How to config DNA A211-i wifi and adsl???? please help
  • Thread starter Thread starter shrikant03
  • Replies Replies 2
  • Views Views 2,032
shrikant03
bsnl
I have bsnl broadband with DNA A211-i modem and i want to connect my mobile with it via WiFi
i tried everything which i can do but there r lots of error....
i upload my screen shots please see it and tell me what to do???
http://imageshack.us/photo/my-images/860/deviceinfo.jpg/
http://imageshack.us/photo/my-images/690/waninfo.jpg/
http://imageshack.us/photo/my-images/59/securityts.jpg/
http://imageshack.us/photo/my-images/834/brideb.jpg/
http://imageshack.us/photo/my-images/233/macb.jpg/
http://imageshack.us/photo/my-images/16/advancem.jpg/
help me please.......
how hard is it to provide the error messages? What error messages?
Also, in the MAC filter - either keep it to disabled or add your phone's MAC address.
(also - the WEP key - seriously, don't keep it at 11111 and change network authentication from Open to something else)
Step 1:
Instead of " Bridging ' In Wan page select PPPoE.
Enter your USERID/PW in modem wan page.
Step 2 :
Enable DHCp in ( Advanced options LAN pge )
give a range say 192.168.1.3 to 192.168.1.10
Step 3 :
Enable UpNp box if seen.
Step 4 :
Select Channel 6 or 11 instead of auto channel 1
Step 5;
Disable MAC filter as mentioned above.
Step 6 :
Security key try without any security key.
STEP 7:
If working OK.
Go to Management and save/backup all settings to your harddisk
say C:/My Documents /dna 212 unsecured wifi ok
Step 8:
Then try wep wpa etc.
Feedback item wise.
For ref : see my STICKY post WA3002_g4 quick reference here.
https://broadband.forum/bsnl-broadband/50052-bsnl-broadband-utstar-wa3002-g4/
Check with Chennai link your settings.
If all Ok Donate Rs 50/= to Ramakrishna Mission. or any orphanage, if you wish.
