How to connect my own router using tplink xz000 gpon.
  • Thread starter Thread starter 404Found
  • Replies Replies 23
  • Views Views 3,632
You can't do away with GPON if you wish to use your own router. Also, if Archer C5 doesn't support individual VLANs, you can set the VLAN in GPON terminal, instead.
No not yet. I may have equipment at home that could serve as a GPON but unless I have the actual instructions I have no idea whether my device will be compatible. So please post the instructions regardless.
Make sure to buy only TP-Link XZ000-G3 v1.
Put the GPON SN you found out like a few days ago, in it.
Clone the JioFiber HGW WAN MAC in your router.
Put VLAN 1015 in router.
Select Dynamic IP as the internet mode and that's it.
