guys i have bsnl dataone Home 500 connection. I was provided with DareGlobal ADSL modem with my connection. recently I purchased Linksys WRH54G wifi router. b4 i had this router i used to connect to internet manually using windows. but latter (after buying router and confging it) , i confg my modem to dial connection automatically. every thing works fine i.e i am able to connect internet ,utorrent is transferring data. But i cannot disconnect from net!!! to do so i have to manually switch off modem. I have confg modem with idle line drop down time of 10 mins. It does work, i.e in wan settings (modem),status is UP but IP is unknown/blank (in idle state ). Now i was thinking of confg my net connection such a way that i connect/disconnect from net manually. that is for establishing/terminating connection a 2am/8am. for that i need help.i used rasdial method when i dint have router.i want to return to my old method(connecting net by PPPoE through my PC),with present setup (modem+router). this is the configuration used for modem and router modem: dareglobalip: 192.168.1.1mode: bridgedhcp: disabled router: linksys WRH54Gwan ip: 192.168.1.2lan ip: 192.168.2.1dhcp: disabled pcip: 192.168.2.3default gateway: 192.168.2.1 i have enabled PPPoE passthrough on my router... but still not able to connect through my pc. Can't understand what else is needed to be done!!! PLS helpnote: i have tired the option of confg router with auto dial, but it doesn't give option for manual disconnect . i have enter routers home page to disconnect. or set an idle time out (5mins default).
