How to Connect TP-XZ000-G7 to Airtel Xstream Broadband?
  • Thread starter Thread starter mystic_235
  • Replies Replies 278
  • Views Views 44,671
Alright bros I tried again and got the internal vlan id via uart. The command was gc_omcicli mib get 171 (or get mib, I forgot) and it gave out a series of string which had to be parsed (Thanks to previous member mostwanted003) and it came out to be 1240. Failed to login due to wrong credentials. Will try out again soon.
Anyone has the XZ000-G7 2024 firmware? The Brazilian firmware seems to not work or upgrade due to regional differences. The XC220-G3v I had is now bricked and cannot do anything to revive it back. IDK why the XZ000-G7 has so much OLT compatibility issues as compared to the XZ000-G3.
Purchased the TP-Link Xz000-g3 V1. I can do a pppoe connection from my personal router( confirms the new onu has no connectivity issues), but I also have a static ip from airtel, when I configure my internet with my static ip,
Internet does not work. Has anybody faced this issue with static ip??
I tried again with both correct credentials and newuser+newpass and I still failed to login. Seems like TP-Link XZ000-G7 is a lost cause for me. Next I'll either go with pc+sfp setup or sfp+fiber converter setup (whichever is cheaper)
@anmolbhard004 @tr1k0N4
I'm a little confused here.
Huawei HG8120C looks like it has a blue connector, i.e., UPC. As far as I know, Airtel provides an APC connector ie Green.
so how does it work?
or does Huawei HG8120C support both? or am I missing something here?
