How to get direct connection from RailWire?
  • Thread starter Thread starter raman07
  • Replies Replies 2
  • Views Views 6,730
Netplus
Hi, I have used railwire internet provided by LCO and their service is not good. So i am thinking if there is anyway to get direct connection from railwire. There website have direct customer form.
Is anyone using direct connection from railwire? Is it even possible to avoid LCO?
Thanks
so what do you expect railwire to do? go behind the back of their local partner and lay down the cable themselves? and then offer you services directly? and what do you expect your lco to do? ignore the cables laid down by railwire that competes with their own service?
there is a reason why dth is so successful. it bypassed the need to deal with cable operators. cable guy cannot sabotage your dth equipment. the same reason why mobile internet is so popular in india. no one can sabotage your connectivity with the service provider. this is also the reason why companies like railwire and excitel partner with lcos. and private telecom operators like airtel pay hafta to lcos not to damage their boxes and wiring in serviced areas.
railwire doest not provide internet via FTTH in Hisar. LCO provide connection with wireless point to point or point to multipoint antennas here. So i am hoping to get direct connection from railwire via PTP antenna. I have seen a YouTube video where a guy is showing his railwire speed and calming that railwire has installed a dish antenna on the building and provide internet in whole building. I can invest 10k on antenna if railwire provide me similar connection.
The guy claim to have 10-20ms ping to google which is pretty good.
