How to Get Maximum Speed on 2.4 Ghz
  • Thread starter Thread starter soorajskn
  • Replies Replies 46
  • Views Views 27,350
Yes. Thats true. on my laptop i get 90 mbps with 2.4 Ghz. But on my Samsung A50, i get only 40 to 50 mbps.
Only if i connect to 5 ghz i get above 100 mbps speed. I problem with 5 ghz is that it wont cover whole house. Its coverage is less compared to 2.4 ghz.
Thats where mesh router workaround. my whole house is covered with 2 routers with blanket 5ghz coverage. all portable device roam on 5ghz only.
I am using Poco X3. Speeds were upto 90mbps on 144 mbps link speed. So was thinking if it would improve if I move to 200 mbps plan.
Never, For a link speed of anything upto 150mbps, mac actual speeds doesn’t exceed 105-110 mbps, that too in very favourable conditions. Ex: Very few interference/less 2.4Ghz based devices in home etc.
Even if you are on 300mbps plan or 1gbps the 2.4 Ghz speeds are maxed out at 110mbps for 150mbps link speed.
U can't get above 60 Mbps under 5 GHz no matter wat u do . Get a small 5 GHz adapter it's not very expensive . It's better than wasting ur money 120 Mbps , that must cost a lot more than buying one 5ghz adapter a single time
@Samuel
Also worked in my case after changing from 20mhz to 40 ghz. It also depends on the device and the link speed.
