first of all it's not 4G. You should call it 2.4GHz network.
Theoretically on 2.4GHz if your device device supports 802.11n standard then you should be getting around 600Mbits/s (around 75MBytes/s) speed. But on ground I have always found that 802.11n supported devices caps the speed at 72Mbps
Hence, no matter what plan you have subscribed for Jio Fiber, on 2.4GHz you will always get 72Mbps or less.
Check your device, if it doesn't support 802.11n and supports older versions of the standard then speed will be way lesser than 72MBps
Note:
150 Mbps (Megabits per sec) = 18.75 MBps (Mega Bytes per sec)
