press list and then press red button until favorite is displayed in bottom of list box...then select favorite 1 or 2......then press ok
I have done it that way and stored some channels in my favorites. But how do I recall favorites. I mean how do you go to let us say favorite 4.:wall:
I dont know how many models of STB or software versions are around in Sun, but this works for me....
[*]Press List button
[*]pressing red button (above ch+) will move the highlight of icons at the bottom of list. press it until 'move' is highlighted.
[*]using the navigation key, move up/down the list to locate the channel you want to move is highlighted
[*]press 'ok' to select the channel for moving
[*]use up/down navigation keys
[*]once you found the position where you want the channel to be moved, press 'ok' again
[*]you can do this for as many you want to move.
[*]pressing 'exit' will save, you will see 'please wait' prompt.
[/list]now, channel navigation using navigation keys will be as per newly ordered list. there are other functions you can do on the list menu, rename, delete, lock, add to favorites.
adding to favorites is another way of grouping your channels. you can have upto 8 favorite lists (not channels) or categories if you wish to call so. I have a favorite list for all tamil channels, english channels etc.
HTH
Well I do not have "move" in the options.
