Incoming connections failing via public ipv6
  • Thread starter Thread starter bagadbilla
  • Replies Replies 3
  • Views Views 1,912
india
reliance jiofiber
Hi, I am on reliance jiofiber and wanted to access my plex media server from outside my lan using my public ipv6 address.
To confirm, using ipconfig /all on windows terminal i get the following output:
Code:
Ethernet adapter Ethernet 5:
   Connection-specific DNS Suffix  . : localdomain
   Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller #2
   Physical Address. . . . . . . . . : █████████████
   DHCP Enabled. . . . . . . . . . . : Yes
   IPv6 Address. . . . . . . . . . . : █████████████████████████████(Preferred)
   Temporary IPv6 Address. . . . . . : █████████████████████████████(Deprecated)
   Temporary IPv6 Address. . . . . . : 2405:201:5010:8867:c824:7523:ea1e:bc5(Preferred)
   Link-local IPv6 Address . . . . . : ██████████████████████(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.29.189(Preferred)
   Lease Obtained. . . . . . . . . . : Wednesday, December 20, 2023 8:55:40 PM
   Lease Expires . . . . . . . . . . : Friday, December 29, 2023 3:54:53 PM
   Default Gateway . . . . . . . . . : 192.168.29.1
   DHCP Server . . . . . . . . . . . : 192.168.29.1
   DHCPv6 IAID . . . . . . . . . . . : ████████
   DHCPv6 Client DUID. . . . . . . . : █████████████████████████████
   DNS Servers . . . . . . . . . . . : 2001:4860:4860::8888
                                         DoH: https://dns.google/dns-query
                                       2001:4860:4860::8844
                                       8.8.8.8
                                       8.8.8.8
                                       8.8.4.4
                                       8.8.4.4
   NetBIOS over Tcpip. . . . . . . . : Enabled
And i get the same ip as above (Preferred Temporary IPv6 Address) from google, so I think it means it is public and not behind a nat.
I have opened the firewall for the port plex is running on (32400) in jiofiber router (i also tested by opening all ports)
But I am unable to ping my host via ipv6 online or check if the port is open:
There might be some firewall issue I might be running into, but I am unable to connect to my device. Please help.
Thanks.
