iPhone wifi dropping issue on Jio fiber
  • Thread starter Thread starter Rockybhai
  • Replies Replies 19
  • Views Views 8,815
U can enroll as a public beta tester to install ios 14.2 which is the final build that will be released to the public soon or you can install a beta profile directly by searching it online to download the ios 14.2
@Rockybhai GM build is as solid as the stable/final build,
But would still recommend to wait for the public release.
As for the wifi dropping issue - I am currently facing non on my XS running 14.1
GM Build is not as solid as stable but is the stable and final version of the particular release ready to be delivered to the public.
@crymetyme GM and final release literally has the same 'Build Number' in most cases,
And it has been the same since I have been jailbreaking my iOS 3 on my 3G then 3GS. Their update roll outs have never changed.
Until they find a serious problem with the GM (Gold Master) build NOT THE BETA then that version is usually pushed out as the main public build too.
@Rockybhai You can diagnose what the exact issue is via a help of a Linux Shell running on your iOS device.
iSH recently exited their TestFlight and is now on the AppStore - ‎iSH Shell
It is basically a Linux on your iOS device - try diagnosing through that. I guess it is my best bet.
@Rockybhai Why don't you just reset the router? There is nothing to lose.
The weird part is that my XS is working fine on both 2ghz and 5ghz and is on 14.1 same as yours. I have never faced random disconnection and reconnection of WiFi of any sorts.
I do not think it is the OS's fault to be honest.
