Is Airtel curbing speed of Filesonic, Fileserve, Oron... and other file sharing sites?
  • Thread starter Thread starter Sapney
  • Replies Replies 114
  • Views Views 17,264
Since past 2 days getting pathetic download speeds of 10-30 KB/sec on Filesonic,other filehosts are giving me normal speeds (200-250 KB/sec).
Anyone else from Bangalore getting low speeds while using Filesonic ?
Do you have premium ? if not then get one
nope,i use it as a free user,never had such low speeds before.
I would get premium,but if Airtel is throttling the speed then what is the use ?
Edit - ok,just tried downloading using a friends Premium account ,getting between 20-60 KB/sec :thumbdown:
Download speeds from different filehosts using same file -
Click images to view full-size
Filesonic -
http://www.imagebam.com/image/31c525166887416
Fileserve -
http://www.imagebam.com/image/5fba89166887447
Mediafire -
http://www.imagebam.com/image/9c1e37166887460
link-removed -
http://www.imagebam.com/image/369005166887481
link-removed -
http://www.imagebam.com/image/46e90d166887491
So,as can be seen there is definite throttling on Filesonic and Fileserve,no throttling on other hosts and torrents for me.
Anyone experiencing similar issues from South Bangalore ?
did you try downloading the filesonic/fileserve files via IDM or the link-removed file via JD?
tried Filesonic/Fileserve with IDM also,slight increase in download speed but not what i used to get before,i mean just 4 days ago as a free user and without even using any download manager i used to get 220-250 KB/sec on filesonic easily.I can only hope this is something temporary.
I am seeing the exact same speed drop in filesonic premium with jDownloader (with Airtel at NCR). Since past two days it was quiet bad (30-50KBps). Today its around 90-100KBps. Its either Filesonice or Airtel throttle. Not sure which
Let me clarify that filesonic not curbing there speed as i have downloaded a small 50 MB MMS clip with decent speed :P
