Sorry kinda new with these terms :\ What is a
VPS and how do you get 1gbps speeds? 0_0
VPS: Virtual Private Server (web hosting on a platform bigger than shared hosting with dedicated resources available to you)
1gbps port can be available depending on the host you choose. No vps provides dedicated 1gbps port, this port is shared usually but better than 100mbps shared port.
If you are a complete newbie i won't suggest getting a VPS. You may end up just wasting your money. As most likely:
- The user who recommended a VPS use a program similar to rapidleech or something.
- The above program is very CPU intensive, so many reputable web hosts do not allow it.
- If the host finds you are downloading copyrighted material to their servers, they will just suspend your account and there will be no refund.
- If you still insist... get a VPS in Netherlands. They have good port speeds and are more lenient than US providers (but may cost more)
- VPS are mostly unmanaged specially if you gonna use it for DL's. You must know how to work in linux to be able to use it properly.
Now coming to airtel
- They throttle torrents
- They are starting to throttle file sharing sites
- The customer service is just not how it used to be before now.
- Their plans "suck" dumb FUP.
- They think it is perfectly normal to drop a guy from 4mbps to 256kbps after he reached FUP (seriously ? at least 512kbps would be acceptable)
- Sadly there is no other reliable provider here in Delhi.
Give us an another reputable provider in Delhi or if MTNL steps up it's services or Beam comes to Delhi... then good riddance Airtel.
