Hello all,
I have a major issue with the so called Airtel premium broadband. Am paying for a 300 Mbps connection.
Things were working fine for many months. But suddenly in feb, speed started coming down to 100 Mbps. Backend team did some setting into manual and it worked fine for 3 weeks. But the issue reverted later.
When repeatedly complained, damn airtel doesn't understand and says connection working fine at their end. This is all they got to say. Mine is a dragonpath router. They replaced it with Nokia router and it worked fine for 3-4 days but then again, issue reverted. Now they again changed this back to original dragon path router. Speed worked fine for 16 hrs and it gave up.
Now they are not helping. In my soceity there is nothing but this Airtel. I miss my Actfiber a lot. No one understands the issue and their backend team is the worst. Not sure how airtel is being good!
Pls help me with any suggestions. Hard reset of the connection via cable or router works some times, but doesn't many a time. I wanted to check if VPN on/off would cause any issues? Because i observed (some times), after i disconnect the VPN, speed doesn't cross 100 but goes to 300 many a time. Airtel router LAN port itself is giving 100 Mbps when tested. Now after a reset, suddenly it works and then again it drops to 100.
