so your ethernet adapter is locked at 100mbps thats why it is showing speed 95 at max
here are steps to do
open control panel,go to network and internet->network and sharing center->change adapter settings->select the adapter you are using like ethernet or wifi->properties->configure->advanced->set speed & duplex to 1gbps full duplex->ok
ethernet supports two ways of speed 100mbps,1gbps both used to save power and resources thing but if your ethernet is at 100mbps then your speed will not go above 100mbps and if it is 1gbps then it can.
you are using 200mbps plan i think so do these think,also you said there's no loss that simply means everything happen to be fine by airtel side and it is configuration issue on your hardware,follow above steps and then try
as you mentioned 'Ethernet Adapter showed 1 Gbps when speed above 250 in control panel, but it shows 100 Mbps when speed is 95 or less.'
