jio airfiber vs airfiber max
  • Thread starter Thread starter goku35
  • Replies Replies 1
  • Views Views 46
IND
Cloudflare
what is difference between jio airfiber vs airfiber max?
Currently I am in hyderabad,
I want to relocate it to rural area in MH, jio says airfiber is not available in that rural area
I have JIO 5G signal in my rural area, will it work after self relocation?
If you are referring to C6 device as AirFiber Max it will not work because it is a P2P Wi-Fi device which connects to A6 SSID of nearest tower, If you have old AirFiber device which operates on 5G network maybe that will work but ODU has some VLAN configuration if those VLANs are different in every state it may not work you can try if it doesn't work bring the device back to Hyderabad you can post pictures or model number of the device which you have we can confirm it is C6 or ODU which operates on 5G
